What is all about web configuration for nokia c3?
Hello experts,
What is all about web configuration for Nokia c3? I am wondering if there is some way to configure the Nokia c3 over the internet web? Can you give me a brief explanation about this; I need at least a little bit knowledge when in terms of mobile devices, thanks.
Best Answer by Dwayne Clayborne
Answered By 0 points N/A #180844
1. Press “Menu”
2. Scroll to Settings, press “Select”
3. Scroll to Configuration, press “Select”
4. Scroll to Pers. Configuration setting, press “Select”
5. Press “Add” or if other accounts are listed, press “Options”, scroll to add new, press “Select”
6. Scroll to the Web, press “Select”
7. Scroll to Account name, press “Select”
8. Press “Clear” to delete text already present
9. Enter Vodafone wap, press “OK”
10. Scroll to the Homepage, press “Select”
11. Enter http://www.vodafone.com/content/index.html press “OK”
12. Scroll to User name, press “Select”
13. Enter wap, press “OK”
14. Scroll to Password, press “Select”
15. Enter wap, press “OK”
16. Re-enter wap, press “OK”
17. Scroll to Use preferred access path., press “Select”
18. Scroll to No, press “Select”
19. Scroll to Access point settings, press “Select”
20. Scroll to Proxy, press “Select”
21. Scroll to Enable, press “Select”
22. Scroll to Proxy address, press “Select”
23. Enter 212.183.137.012, press “OK”
24. Scroll to Proxy port, press “Select”
25. Enter 8799, press “OK”
26. Scroll to Bearer settings, press “Select”
27. Scroll to the Packet data access path., press “Select”
28. Press “Clear” to delete text already present
29. Enter:
30. Press “OK”
31. Scroll to Authentication type, press “Select”
32. Scroll to Normal, press “Select”
33. Scroll to User name, press “Select”
34. Enter wap, press “OK”
35. Scroll to Password, press “Select”
36. Enter wap, press “OK”
37. Re-enter wap, press “OK”
38. Press “Back” three times
39. Scroll to Vodafone wap, press “Options”
40. Scroll to Activate, press “Select”
41. Press “Back”
42. Scroll to Default p configuration setting, press “Select”
43. Scroll to Personal configuration setting, press “Options”
44. Scroll to set as default, press “Select”.
Answered By 0 points N/A #180845
It depend on your ISP .No hard steps, Simply ask Web configurations from your ISP, dial customer care support and ask about web configuration settings. Then save it manually. Then you can activate your Web.
Good luck
