What is all about windows advanced module?
What is all about windows advanced module? And how is it related to those recovery management tools all over the internet. I just want to know the advantage and disadvantage of this kind of module. I am wishing for your opinions and ideas regarding this matter for I need a little bit knowledge about this.
Thank you.
Best Answer by Johnstoon Leen
Answered By 5 points N/A #173852
Windows Recovery is fake, if you haven't activated it's fake "advanced module" thing then I suggest you get rid of it immediately. This program is like a virus it alerts you about fake security messages and performs fake computer scans. To remove it from your system follow the steps on this guide :
https://www.howtogeek.com/howto/windows-vista/disable-system-restore-in-windows-vista/
Answered By 0 points N/A #173853
Hi Any Hill
It sounds like a virus and fake.
Well it is related to windows recovery system analysis and optimization program.
It displays the wrong system information in order to display the wrong error messages and security warning on infected systems. “Advanced Module is one of this”.
These types of messages states something is false with your system and hard drive.
They will refer you to download and install a program to get rid of this.
When you’ll click after that window’s Recovery install and automatically run into your system to damage your files.
In actual this program is fake and scam.
Use any good Antivirus and make sure that this kind of virus will not attack on your system in future.
Good Luck!
Johnstoon Leen
