What's the best alternative application camera nokia lumia other than the Creative Studio installed? What I'm looking for is an app that can resize the picture to 3264×2448 so I can fully utilize the super sensor and turn it into a thermal camera. Wouldn't that be cool?
What is an alternative Application camera nokia lumia?
Hi Frank,
I don't think there is other available app similar to creative studio for Nokia Lumia but find out for their latest apps available. Well, 8 megapixel camera is 3264 x 2448. It would be cooler If you'll go for an extreme art challenge , use photoshop instead or other photo correction software that you are familiar with and resize 3264 x 2448, then after this process, use software to unsharp, mask, sharpen the photo, There you have it, the final product! you can now print at 300 dpi and get this super 7.5 x 10 photo.
Hope this works
Steele Ney
