Bersh Roman
30 points
Posted on - 06/29/2012
I know that there are many anti-virus software that claim to be the best for desktops and laptops.
I noticed that my anti-virus on a non-apple desktop does not work as well on my MacBook.
What anti-virus works best with apple products, specifically my MacBook?
What antivirus software works best with Apple products?
Hi Bersh,
A lot of people using Mac doesn't bother with choosing an Antivirus software which I think is a risky thing to do.
For you to compare different Anti viruses on Mac you should base it on Speed because some Anti viruses lag your PC down and off course on affectivity of finding viruses and protecting your system.
Below are some of the best reviewed Anti viruses of the Mac OS:
1. Intego VirusBarrier
2. Norton AntiVirus for Mac
3. BitDefender Antivirus for Mac
4. Kaspersky Anti-Virus for Mac
5. ESET Cybersecurity for Mac
6. F-Secure Anti-Virus for Mac
7. Trend Micro Smart Surfing for Mac
8. McAfee VirusScan for Mac
9. ProtectMac AntiVirus
Hello Bersh Roman,
Thank you for that interesting question. I think there is no need to install an antivirus to your MacBook because most of antivirus software are junk and harmful. Just follow the following steps to make your MacBook secure:
1. Click "Safari Preferences", then uncheck "open 'safe' files after downloading
2. Un-check it. It will give protection measures against application automatically downloading.
3. you don't need to install malware because there is an existing malware and supply administrator name and password.
The only malware that I can recommend you is "iLife 11". If you came across to their site don't hesitate to download it you deserve it.
You must also be knowledgeable of phishing and ignore pop-ups.
Hope this information will help you.
Dear Bersh Roman,
I agree with John that there is no need to install anti-virus software because it will just harm your MacBook. Just follow the steps given by John and hope it will help you solve your problem. I believe that you can find a way to solve it.
