Hallo!
I have received a recommendation to use Namebench to use as the fastest server finder for Windows. This is with the intent of establishing the fastest server for faster internet experience. I have tested the application and it is working very well, if not perfectly. What I do not understand is whether this application modifies my computer in any way. Thanks big time for your help.
What application can I use for fastest server finder?
Namebench is an open-source tool that locates the fastest DNS servers for your PC. Therefore it is completely free of charge and available for you to use. It does not change your system whatsoever, in any way. It runs a thorough, impartial and robust benchmark using the tcpdump output, web history and/or standardized datasets to provide specialized recommendations.
Check this out for more information on this: https://code.google.com/archive/p/namebench.
