What are the Advantages and Disadvantages of Advanced Browser?
Hello friends,
What are the advantages of advanced browser? I am using Mozilla Firefox internet browser in my windows 7 starter operating system. There are times that the browser is not responding well with my actions during surfing and chatting online. Can you give me some advice about having an advanced browser? And also give your best recommendation.
Thanks and Regards,
Timothy Raine.
Best Answer by Howard william
Answered By 0 points N/A #184969
“Advanced browser” has some advantages like it is fast, you can separate your favourite sites and reorder them as your wish. It also has a pop-up blocker for easy and safer surfing. Though “Advanced browser” have some advantages, I suggest you to have “Google chrome” instead of “Advanced browser”, because “Google chrome” comes with more features than “advanced browser” and easy to use. More over “Google chrome” has built in flash and pdf support.
Answered By 10 points N/A #184970
Advantage of advance browser–
1.You can do private browsing.
2.Support HD picture and video and you can watch them online.
3.You can read pdf  and other doc file online.
4.It is more secure,
5.Interface is user friendly and user can easily understand how to use it.
6.It is fast.
7.User can install browser extensions which makes browsing very enjoyable.
