What are advantages and disadvantages of bitdefender 6?
I am using NOD32 AVG at the moment, but I would like to change it as soon as possible. I like to surf a lot on the Internet, so I need a really great security program. Maybe somebody know what are advantages and disadvantages of bitfender 6? Besides, I am using Windows os.
Thank you.
Answered By 5 points N/A #134730
Dear user,
Here are some advantages of BitDefender Antivirus Pro:
1) This software protects you and your PC from all kind of viruses and spam, it scans all web, IM, and email traffic for malware.
2) It is a well-designed and organized software which is easy to install.
3) It automatically perform updates and does not slow down your computer while you work.
The main disadvantage with this software is that it may malfunction sometimes, which means that you not able to logon into your server.
Hope this will help you.
Thank you.
