Hans Chris
Posted on - 09/04/2011
Hi,Â
My laptop only has one jack or port for headset and if I need to use the microphone that won't be possible so I'm planning to purchase a bluetooth headset. Do these kind of headsets have a certain specifications or perks that I need to consider. Also, does these have certain bad effects on our health due to radiation or something. I know that you're not doctors but based on experience is it working well with you.
Also, an add-on question can I download Adobe Photoshop for free in the internet or do I need to purchase one. If there is anything free what site can I download it.
Please help me.
Thank you.
What are the advantages and disadvantages of using a bluetooth headset?
There are many advantages for using Bluetooth head phone. You can use your head set from anywhere in your room and in the range of your Bluetooth devices. There is no cable trouble or no pin trouble in this technology. So you can use it more freely and comfort then others.
The disadvantage is that you have to use it in the range of your Bluetooth device. So if the range is small then it could be a problem. You will face some unnecessary memory loss because Bluetooth driver uses lot of resources and these resources uses more memory space.
You can download Adobe Photoshop for free from this site.
1.      https://filehippo.com/
2.      https://en.softonic.com/s/adobe-photoshop-7.0.
If I to post a questions regarding bluetooth headphones, my questions would be like this;
Are Bluetooth headphones safe?
There are numbers of reasons, disadvantages and advantages of using bluetooth headphones.
* Disadvantages – Can contaminate inner ear caused by excess usage. Radioactive gamma rays is the common problem of using this device.
 – Uses radio active signal and can cause cancer.
* Advantages – Green environment friendly which is manufactured by Orange company known for following ISO product's good for environment.
  – Can talk to the phone and be safe while driving hands free.
HiÂ
Check this Techyv post to get more information according to advantages and disadvantages of Bluetooth device.
Using Bluetooth mouse and keyboard
