Hello techyv,
What are the advantages of web database creator freeware? Give me all the possible feature of a web database creator freeware. I am using MySQL database and want to venture to another face. Share with me your experiences regarding this matter.
Expecting some help from you guys.
Hi Christine!
The main advantage of using a web database is that you can access it at any WiFi hotspot.
For a database driven website, the advantages of using a web database are:
You can easily collect and share information from online surveys, customer feedbacks, and event registrations.
You can easily update your website’s product catalog, work progress with customers, and distribution of daily sales or inventory reports.
I have used WAMP's database management system and it is easy to use. You can easily create and edit MySQL databases in the web with it.
Hello Christine
I am using a Zoho creator now, its a pay as you go service with no long term contracts the price starts at $25 a month you can even choose to pay it yearly. Getting a free data creator will only mean you have to buy the complete version, you can only use the software in a limited time and few options on the program.
Its a promotional copy so you can either buy its complete version or ignore and uninstall it. Just try a bit of some of these free software and if you are satisfied with one, then consider buying the full version.
Hope this helps you.
