What are the available best addons cs3 for Photoshop and InDesign?
Hi
I installed Photoshop and InDesign CS3 into my computer.
I need to improve the options in this installed software.
So I need to know what are the available best addons cs3 are for Photoshop and InDesign.
Thank you
Best Answer by Johnstoon Leen
Answered By 5 points N/A #148164
Dear user,
You can download IndicPlus which is an Adobe InDesign CS3.
It supports in InDesign involving Bi-Directional Complex Scripts.
It also allows you to use Unicode Fonts within InDesign.
It can also support many international languages. You can either buy it or download it for a 7 day trial.
Hope this will help you.
Thank you.
Answered By 0 points N/A #194856
Hi Jaclyn Andee
There are many best CSS add-ons for Photoshop and InDesign.
You need to know about what you required from specific plug-in or add-on.
Best CSS Add-ons for Adobe Photoshop
3D Invigorator (Easily Create complex 3D logos, text and objects using vector artwork)
Contrast Master (Light room editor, contrast enhancement and dramatic contrast look)
Retina (Maximizes Perceived contrast, brightness, sharpness, depth and resolution using a proprietary model of human beings)
Best CSS Add-ons for InDesign
5-Star Brochure Bundle (4 top rated brochure, 3 Bonus print ads)
How to Present Template (Eye catching print brochure)
Mail order catalog InDesign Template (Create modern and clean catalog by using a grid based layout)
These are the best CSS add-ons for both Photoshop and InDesign.
I hope you’ll select which one you required for your specific purpose. Good Luck!
Johnstoon Leen
Answered By 0 points N/A #194857
I am use plug-ins on my Photoshop.
Here are some of the best, in my opinion: filter hub, color styler, B/W Styler,
ColorWasher NEW Version 2.05 for MacOS X
LightMachine NEW Version 1.04 for MacOS X
ContrastMaster NEW Version 1.04 for MacOS X
Plugin Galaxy NEW Version 2.02 for MacOS X
PhotoFreebies and many more.
Visit for more information and there are also four more that I designed.
You have to buy all of the plugins, but they all have a 7-day free trial.
Max
