What are avast system restriction for some software?
Where can I find something about what are avast system restrictions for some soft wares and how I can manage these?
One of the "Avast" antivirus functions is that it blocks potentially risky programs that are harmful for your computer. It blocks all such applications and does not allow to run these applications. But in this restriction another problem is that it sometimes block some safe programs for which we have to create an exception.
1-Double-click the "Avast" icon on your desktop, Click "Real-Time Shields" in the column on the left of the Avast interface. From the drop-down menu select "File-System Shield. Click "Expert Settings," and then click "Exclusions". Now you will have to add the program that you want to exclude.
2-Click the "Add" button and go to the .exe file you want to exclude. Select the .exe and click "Open". This application now becomes excluded.
Notifications
