I have a project right now in flash which is the 3d explosion flash effect. I'm having trouble creating this project because I don't know where to start. Is there anybody here can give me some idea of what will be the basic? Where should I start?
What are the basics when making 3d explosion flash?
Hi Bertha,
Adobe Flash itself does not support it's own 3D effects, though there are some built in features, they are still a bit simplistic.
If you want to incorporate 3D explosion effects in flash, you will need some 3rd party softwares.
Particle illusion would be my suggestion. Get it here – https://particleillusion.en.softonic.com/
Particle illusion allows you to create and export 3D effects in GIF or Image Sequence, which you can then import to flash.
Hope this helps.
