Dear Friends
I am doing a project which requires me to write a simple database application. Some of my friend suggested me to use PHP Framework. Can anyone tell me what are the advantages in using php wizard framework instead of PHP and mySQL ?
What are the benefits of using php wizard framework
Hello Beeky,
If you are not comfortable with writing code for PHP and MySql on your own, then the advantages of using a PHP wizard framework would be very beneficial.
The framework wizard will walk you through creating various PHP web applications. You will finish your code faster with attractive URLs that meets constant architectural and coding standard. Your code will be simple and clean, therefore making it easier to gain assistance when needed. And make it easier to create plugins easily. Plus, since most websites require similar features, you can easily debug and reuse your code on other sites.
Winchel Shirlyn
