What are the Best Cheap European Dedicated Servers
Our team is planning to develop an online game. But we want to know if there are any cheap European dedicated servers that we could lease for the game. We want to prepare our budget ahead. Could you please suggests cheap European dedicated servers and the price? Thanks.
Best Answer by Baker Mich
Answered By 0 points N/A #143336
There are so many cheap European dedicated servers found in the website.You could take on lease also,but before that you need to chat with them on line, else talk to them on their helpline no.you should mention your budget to spend in a month for taking server on lease.I herewith attach few links you can see the rate as per server configuration.
Answered By 5 points N/A #194923
Hi there,
I would suggest you to check
https://www.hetzner.com/?country=en
It provides one of the best services in Europe in terms of cost and overall service that you are looking.
Considering you are in need to run online games on your website you will need a server that runs without goof up and provides seamless services. There is a lot in that category but differentiating on cost factor I would suggest you the above mentioned web host.
Hope this helps.
Thanks
Baker
