What are the best features of Samsung galaxy note 8?
Hi guys, I have Samsung galaxy note 8 and though I'm using it just simply a normal user kind of I'm not a tech though but as I purchased a famous almost perfect kind of galaxy note I want to know what are the new features in it that any other tab or note does not have and also connectivity is a great requirement for me what are the options available in it.Please tell me
Answered By points N/A #187867
Samsung is the greatest Tech giant in the case of smartphone. It’s been providing users with many awesome smart devices. Galaxy Note 8 is the best for all purpose. It comes with heavy features and advantages that can hardly be available from others.
The main focus should be the device’s hardware configuration. Galaxy Note 8 comes with 2GB RAM, 1.6 GHz processor and Android 4.1.2 that supports Android 4.4. Batter life is also satisfactory, Li-Ion 4600 mAh that can last for quite a long time. It’s good enough to make someone’s day.
The multimedia functions are also awesome. It supports microSD upto 64GB. Multi-tasking is also supported. Working with graphical job is quite amazing.
You can find out more about its features here.
It should turn your heart full with joy. I recommend you to have one.
