I need an online comprehensive PIM that would maintain security of my data through encryption. It's part of the website that we're developing. Could anyone give me the best online encrypted pim applications that are cost-effective and reliable?
What are the Best Online Encrypted PIM Applications
There is this new PIM application called Pimero. It’s an online encryption system that deals with appointments, events, reminders, tasks, contacts, emails and even web feeds. Its graphical user interface is also worth mentioning. Luckily this software has a free version but trust me the commercial one is worth everything.
To download the free version which is limited to only one user, follow the link http://www.pimero.com/en/purchase/
To download the commercial version, follow this link https://www.pimero.com/en/.
Hi there,
As we all know that looking for efficient PIM catering to your need is a difficult task however there are few available which can be best for you. I would suggest having one below which has a social network dimension associated with it. Click on the link below to get that same. This one also supports email encryption.
http://www.efficientpim.com/
This software has 30 days trial version which would help you give a sure try.
Hope this helps.
Thanks,
Baker
