What are the best sample brochure illustrator available?
Hello everyone,
I hope you have a great day. I'm looking for the best sample brochure illustrator available in the market right now. Please include specific key features and overview of the sample brochure illustrator that you can think of. I need something that is efficient, quick and is easy to configure. If you could provide a step by step instruction, then that would be perfect.
Best Answer by May Molinaro
Answered By 0 points N/A #137751
Hello Romasfleeman,
There are lots of great of sample brochure illustrator on the market. I will be guiding you to get into the direct links of the sample brochure illustrator. Let me give you some examples of brochures.
Go to these links:
BROCHURE Adobe Illustrator Templates
BROCHURE Tri Fold Brochure Template
These templates are easy to customize the layout and graphic files and it works with Illustrator.
Answered By 0 points N/A #137752
Whatever the purpose of your request, brochure illustration is a complex field with a wide array of products in the market.
You may check this link for the program that may suit your concern. Note that you need to consider the Desktop/Laptop requirements that comes with each software. For ideas of sample brochure layouts, you may want to try this website.
If you are more familiar with Adobe products, you can try using InDesign.
Step by step tutorials by Nick Davies are available in Graphic Design Employment.com.
Hope these suggestions answers your concern.
Answered By 0 points N/A #137753
Hi Romasfleeman,
Brochure is indeed a great tool for marketing. For it to be effective, there are important things that you should consider. Click the link below for a helpful article about making a great and effective brochure.
Creating an Effective Brochure
Here are also some of the Best Brochure Designs for Your Inspiration. There are several software that you can in making brochures such as Photoshop, Illustrator and InDesign. In fact, adobe is offering free templates that can be downloaded and ready to use. But for people who are not Adobe users, Microsoft is has less complex tool that can help you make brochures such as MS Word and MS Publisher. They have also pre-installed free templates that one can use.
