What are the best sound wave analyzers?
What are the best sound wave analyzers? A sound wave analyzer which is compatible with Windows operating systems, there are some instances that we need to use this for important reason and especially when about business and personal use. I hope you can give me the exact information needed.
Thank you.
Smith Agail.
Best Answer by Jemison Stacy
Answered By 0 points N/A #169187
Hi Smith,
This kind of instruments is usually used to measure relative amplitudes of single frequency components of complex waveforms. There are some freeware tools available like Spectrum Laboratory. Also Sonic Visualiser should provide what you need. It was released under the GNU License, and available for both windows and Linux. Hope this will help you.
Answered By 0 points N/A #169186
Hi Smith,
You want to get better sound analyzer so do not worry about that you can get many best sound analyzer I recommend you should to get Precision Audio Analyzer by using www.boonton.com it is the best sound analyzer and you can get easily. Hopefully this information will help you.
Thanks,
Raun Nelson
