What are the best webmaster tool training? I want to be the best when it comes to web developing, would you love to suggest and recommend a software which is easy to use that can handle Php and html programming languages? And also include the proper use and terms and conditions of the said application.
Handling a webmaster role & developer role at a time is an awesome task. To start with I am providing here some of the best links for learning from scratch.
For editors that can handle html & php quite well I would first recommend the simplest & best one Microsoft Expression Web4.It is now available for download at no charge. Free versions do not carry technical support. To download the free version click here http://www.microsoft.com/expression/eng/
Expression Web can be used to design and develop web pages using PHP ,html,JavaScript,ASP.NET,AJAX etc.
Expression Web is a replaced version of Frontpage.So you can understand how simple yet powerful will be this editor.
For the better learning of web development, I would recommend you reading about the technologies used:
HTML,JAVASCRIPT,AJAX,CSS,XML,JSNON and languages like php,java, ruby and many more.
To become a good developer, a good start can be Ruby on Rails.
The best Software to handle the languages like html,php are:
Dreamweaver: CS5 is a full featured editor that allows developers to design visually as well as directly within the code. It supports PHP and enables developers to create websites using HTML 5.
Note Tab Pro also supports HTML,java, javascript,PHP and many others. It is text editor on steroids.
I recommend you sites for webmaster tools training. I hope it will assist you to become a good developer.
1....
