There are ways that can determine the error of the Hard Disk Drive that can cause bad sectors and many more. Windows XP provides the way to check the disk error by clicking the Hard disk drive’s properties. According to computer geeks and software makers, there are tools that can check the Hard Disk Drive if there is an error.Â
So guys, here is my question. What is the chkdsk tools error checking software that has been made through the top of the list? Any help would be appreciated.
Thank you very much.
Brant Joseph
What are the chkdsk tools error checking software?
First of all, you can run a Check Disk on your Windows to scan and fix the errors on your hard drive. For other ways to check your hard drive for errors, you can use any of the software below:
1. Ariolic Disk Scanner – this is a free and handy utility that will check your HD for reads errors and sectors.
2. HDDScan – this is also free that can test your HD for errors. It supports USB drive, Firewire and RAID.
3. Windows Surface Scanner – this will help you scan and finds the bad sectors on your HD.
4. SeaTools – this is designed for Seagate HD but it can be used with other brands. And it supports various kinds of hard drives.
https://www.seagate.com/in/en/support/downloads/seatools/
Hello Brant Joseph,
Provided all comments are good as well I will recommend you to visit another techyv page which is contain such kinds of problems information. So visit techyv page " Bad sector in Hard Disk"  and get more info.
