I am wondering if there are criteria that I can use as basis to know that the application works in versions 2.2 and 3.0 of Android OS?
Like for example,
It can be installed
The response time is fast
It supports the screen resolution…
Please guide me.
Thanks
What are the compatible drives in android?
Andrelle Android is the fast growing mobile software which is running on a great sale and is especially it is used by Galaxy series of Samsung where as Nokia using windows.
The type of applications that can be installed are from the android market which can be available for free and the version that is running at now is 2.2Version.
Even the response time is almost good when compared with other software applications and also this response time affects easily so its glad that response time is not affecting the applications.
The screen resolution is medium and that will be worked fine when compared to other so its preferred and overall performance is good with an android.
Thank You.
