What are differences between profile scheduler v.s llama?
Hi guys,
I need someone helps me to find down what differences between Profile scheduler v.s llama are.
Which soft is the better one?
Thanks
Hi guys,
Thanks
Hi Jermaine,
If you are using Jelly Bean, there may be some issues on both apps, addressed by the app developers on their respective site.
In terms of which is better, it would depend on your requirement, although Llama has the upper hand with lower price and better customizability plus less battery drain (it could simply use cellular network location positioning), Profile Scheduler is actively updated and leaves room for new features request, and also a better user interface.Â
Apart from that, they perform similarly.
To sum it up, Llama is has more customization options although you might get confused in the maze of options; whereas Profile Scheduler would be more straight-forward and less daunting to use due to its user-friendly interface.
But generally, Llama is better in terms of functionality and customizability.
Hope that helps! 🙂
