kevin rith
20 points
Posted on - 11/19/2012
Hi
I am a beginner of Computer networks and need to do some research about the Access Control Lists. So I am curious to find out the differences between the each access control lists. So what are the different tools that can compare ACLs?
Thank you
What are the different tools that can compare ACLs?
There are several types of Access Control Lists (ACLs). Out of these two main types are
1. Extended ACLs
2. Standard ACLs
You can divide or compare different types of ACLs on the basis of your network filtration requirement or according to the policy implemented on your network. You can compare ACLs using following criteria,
· Ports (Source Port, Destination Port)
· Mac Address (Source, Destination)
· IP Address (Source and Destination)
· Traffic type
· Protocols (tcp, udp)
