Hi everyone,
I want to know what are the features of Pure digital flip mino pocket camcorder? I have searched to know this camcorder features a lot but with no help I have to ask it here. Though I found some reviews of it but they were really short to get on some decision to buy this or not.
de Blair
10 points
What are the features of Pure digital flip mino pocket camcorder?
Micro drive camcorders are really very fascinating device. These small, cute but highly efficient devices are really hard to resist. Flip Mino from Pure Digital is one of such a gadget. Well before you purchase one, you should know about some of its features, pros and cons:
This is 2X0.81X3.9 inches, cigarette box kind of device which weighs just 0.23 lbs. Able to take digital shots as well, having CCD 680K pixels. The minimum focal distance is 3.3 feet. Abel to zoom up to 2x. Lack of Image Stabilization facility is a problem. But it has a decent LCD Panel of 1.5 inches. The battery lasts up to 4 hours, but 2 GB inbuilt memory allows only 60 minutes recording. Lens Systems- without Optical Zoom. Supported maximum still image size is of the resolution 640 x 480. The company gives a 1 year warranty. Flip out USB arm plug facilitate you to connect as well as charge this little devil directly with computer. It comes preloaded with “FlipShare” software which helps you to manage your videos.
Well at last will say you should defiantly go for it.
Hope this will help you.
