What is are the functions of GSM?
Please let me know the functions of GSM elaborately, as well as the interfaces of GSM. I need this immediately.
Estherr
Estherr
  One of the features of GSM or (Global System for Mobile ) is the Subscriber Identity Module or commonly called "SIM". It stores different information like the id number of the subscriber, the list of networks available to a particular subscriber, pin codes and the like. Every SIM consists of 4 digit ID to activate from any GSM (SIM) capable phone. Before, SIMS are as big as credit cards which can be inserted into a phone, but now they made it so small that it takes a little of space from your GSM. Another feature of GSM is the ability to provide on-the air privacy. The privacy is maintained by the cellular carrier and is encoded to a specific key. There are several interfaces for GSM including: Bluetooth which is categorized into two (Profile and Class) and CDMA or (Code-Division Multiple Access).
 Hope this Helps.
GSM stands for global system for mobile communications. Here I listed below the basic functions of GSM.
1. Transmission- Here user information and signaling information sent through MS, BTS and BSC.
2. Radio resources management- Establish, maintain and release communication links between MS and MSC.
3. Mobility management- Location management, authentication and security.
4. Communication management- Call control, supplements and short message management.
5. Operation, administration and maintenance- To monitor and control the system as well as to modify the configuration of elements of the system.
Various Interfaces of GSM:
1. GSM radio air interface
2. Abis interface
3. A interface
4. SS7
Hope this helps you.
