anonymous
7060 points
Posted on - 10/18/2011
Hi there,
What are the functions of a Window Operations menu?
Thank you.
Luke2014
Without an operating system the computer world would be like a river without a bridge, connecting two villages. An operating system is the core of a computer. Without it, there will be no communication with the computer. Thus it works as an interface between the computer and the outside world. It is what you command to have your computer working.
It is also an interface between the computer and other hardware, like the mouse and monitor just but to mention a few. Drives are another major thing, that play a big role in the operating system. That is why, whenever you install a new hardware on your system, it will ask you to install a new drive. Thus operating system is the core component in a computer.
Fjola
The menu you see, when you click the menu button which usually has the window icon on it or when you right-click the title bar, is the windows menu.
These are the current contents: Restore – to restore the window.
Move – to move the window where you want to place it.
Size – to change the size of the window.
Minimize – to minimize it to the taskbar.
Maximize – to maximize it to full view.
Close – to terminate the current window being used.
If you don't have a mouse and need to resize, move, minimize, maximize or close a window; it is the only way to go. Alt+F3 will drop down the menu and let you perform the window operation that you would like to use.
tam123
The function of windows operations menu is to operate the contained commands for the performance of selected data. The Operations Browser displays the hierarchy listed in all tools in the toolbars or menu. The Macros function must be selected to run macro, start recording the macro, if you what to stop the recording, just select the cease macro recording and the editor of macro just select the Macro editor.
The function of the statistics is to compute the selected items or display the result from the separate dialog and the histogram. You can display a histogram from the selected data. Filter can be choose from the options like convolution, media and smooth. The rotate option can rotate an object to either side or any degree.
There are three functions of the transforms like resample, you can select a data using parameters, rotate the data without affecting the rest and scale data. You can also select an object in the scale factor. The Morph can be chosen from the options like dilates, erode, and morph open, morph close, gradient and top hat. The function of this, is to operate the erosion or dilation and to subtract the eroded version or the result of the original image.
Windows Operation Menu is located at the upper left part of the screen. It displays the name or the main part of the window. Basically, this is the header of the main page.
This is useful in some ways, because this allows you to drag, drop, resize and move the screen to any place you want it to be at.
It'll give you an option to move, resize, minimized and maximized. This also provides you shortcut keys to close the screen itself.
By using Alt + F3 function keys, you can control the screen and do the following features mentioned above, such as move and restore windows without using the mouse control.
