What are important tools during maintenance?
Hi guys,
What tools that are important to you when doing maintenance of a computer system and how can I maintain the good condition of my system?
Hi guys,
Maintenance tools:
1. Cleaning tools:
Need to remove the junk files off the computer. eg. CCleaner.
2. Uninstaller:
Some stubborn software do not want to uninstall by the windows uninstaller. eg Revo uninstaller, IObit uninstaller.
3. Software updater:
The software should be regularly updated. eg. AppSnap, QWinApt, Techtracker.
4. System info tools.
5. Trouble shooter/fixer: FixWin, MicrosoftFixit.
Steps for Maintenance:
1. Disc maintenance.
2. Run only the programs being used by the computer.
3. Keep your Computer clean.
4. De-fragment regularly.
5. Check the power supply.
6. Update Operating system.
7. Turn off rightly to avoid Hard disc crash.
Caringal Cheong
System maintenance is very important for computers same as other equipment or devices but unlike other machines or equipments, system maintenance is twofold; there are hardware and software maintenance.
Just like replacing worn out and broken computer hardware, computer software may be obsolete, have craft or the core operating system be infected with viruses. Some of the tools that may be of help in computer system maintenance are but not limited to;
In order to maintain a good condition for your computer system, you need to do the following;
