What are LEDs and what are they used for?
A LED or a Light Emitting Diodes are a distinctive type of diodes. Diode is a electric element that lets the electricity go by through it from a single route only. What is good on LED is that they glow or produce lights when connected to a correct electric line which is similar to a light bulb. When LEDs are settled side by side, it can produce pictures such as those moving red LED signs that we see on different areas.
Hy
LED means Light Emitting Diodes. It is one kind of lighting technology. And it can give an actual picture dimension. It can save the energy and battery life. The LED lighting quality is better than LCD or CRT. Most of the people like now LED monitor in their computer. LED cannot show negative picture in the rotation view. On the other hand LCD monitor give negative picture in the rotation view. So 180 degree is the actual rotation view for LCT, which is very disgusting.
LED lighting technology can save the electric power and which can save a lot of energy.
There is not much to say about LED. LED stands for Light-Emitting Diode. A diode is something that has somewhat two parts; one is that it allows electric current to pass in one direction while the other part blocks the electric current from the opposite side As we can see the meaning says “light-emitting” as sources say they emit light but not that intense. They are semiconductors of light. In the past LED only emitted low-intensity red light. LED on modern times is now used in our televisions. There are also infrared LEDs; these can be found in remote controls. I attached a photo of an example of a LED TV.
