What Are Microsoft Lumia 950 Dual Sim Features?
I am interested in buying Microsoft Lumia 950 dual sim, but I don’t know about its features and configurations. I am a bit confused. Tell me about Microsoft Lumia 950 dual sim features?
Microsoft Lumia 950 is a good option as compared to Lumia 640 XL black. It has several features but also lacks some. Its features are –
1. It is 150g in weight and has dual sim, micro sim and dual stand by.
2.) IPS LCD capacitive touchscreen, 16M colors.
3.) It has the 5.2-inch screen with 720*1280 pixel screen resolution and gorilla glass display.
4.) Windows operating system 10 by default with Qualcomm sSnapdragon400 processor. With a 20MP camera with autofocus and a 5MP front camera, it has 3 GB RAM and 8GB ROM.
5.) It is WLAN supported, Bluetooth supported 000mAh Li-ion battery. It supports LTE.
If you want to know the specifications of the Microsoft Lumia 950 Dual SIM, here they are. The Microsoft Lumia 950 Dual SIM is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled to the public on October 2015 and released on December 2015 measuring 145 x 73.2 x 8.2 millimeters and weighing 150 grams.
It uses dual nano-SIM card and has AMOLED capacitive touchscreen display with 16M colors at 1440 x 2560 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass 3 featuring ClearBlack display. It runs on Microsoft Windows 10 powered by Qualcomm MSM8992 Snapdragon 808 chipset, Hexa-Core (4 x 1.4 GHz Cortex-A53 and 2 x 1.8 GHz Cortex-A57) processor, and Adreno 418 GPU.
It supports microSD expandable up to 256 GB. It runs on 3 GB RAM with 32 GB internal storage. The primary camera supports 20 megapixels with f/1.9, 26mm, 1/2.4″, 1.12 µm, Carl Zeiss optics, OIS, autofocus, and triple-LED RGB flash featuring geo-tagging, panorama, HDR, face detection, and PureView. It supports 2160p video recording at 30 fps with stereo sound rec. and 1080p at 30/60 fps (after SW update).
The secondary camera supports 5 megapixels with f/2.4 and 1080p video recording. It supports 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band and hotspot support; Bluetooth 4.1 with A2DP support; GPS with A-GPS, GLONASS, and BDS support; NFC; FM radio; and USB 3.1 Type-C 1.0 reversible connector. It has built-in iris scanner, accelerometer, gyro, proximity, compass, barometer, and sensor core sensors.
The pre-installed web browser supports HTML5. Java is not supported. It runs on removable Li-Ion 3000 mAh battery with standby time up to 288 hours both on 2G and 3G. Talk time is up to 23 hours on 2G and 18 hours on 3G. It is available in black and white colors.
