What are the migration models to use in case of Software as a Service platform change? I am planning of changing the Software as a Service platform am currently using due to the fact that the platform is not giving me what I really need. What are the various data migration model that must be in place before attempting this task?
What are the models to use in SaaS platform change?
Hello Berta!
Depending on what you are migrating to, yes, there exists a migration model for a company that leaves its current software as a service (SaaS) platform. A lot of opponent SaaS products will write tools that can import from another service. For instance, if you start using Intercom.io, part of its setup process allows customers import from other analytics or challenge services, like Mixpanel. It may not be within the companies.
Mathew Tand
