What are the mostly used shortcuts for MS Word?
I wanted to know all the shortcuts of MS Word. But if you know some of the shortcuts then it is ok too.
As I am new to MS Word, I was looking to know all the shortcuts so that I can complete my works as soon as possible.
Best Answer by jjbeth
Answered By 0 points N/A #117103
There are a number of shortcut keys used in MS word that can be very helpful in times that you are rushing with your work and if you can be acquainted with them by heart then creating documents and other files in Microsoft word is as easy as 1 2 and 3.
Although at the beginning they can be really difficult to remember because aside from the fact that there are a lot of shortcut keys, it can be very confusing as well. In the image is a table composed of the most common shortcut keys used in MS word.
Answered By 5 points N/A #117105
There are lots of Shortcut keys of MS word. Most commonly use shortcut keys are CTRL+C (for Copying), CTRL+V (for Pasting), CTRL+Z (For undo), CTRL+Y (For redo), CTRL+X (For cut), CTRL+B (For bold).
Beside then please click on https://www.computerhope.com/shortcut/word.htm for other shortcuts.
