Ben Thern
Posted on - 09/04/2011
I just bought a new laptop and I don't want it to be damaged not broken immediately so I want to know what are laptop accessories that I should really have to prolong the life of my laptop. Because I know compared to desktops, laptops are more vulnerable to damage and it tends to overheat immediately.Â
Please help me.Â
What are must-haves laptop accessories?
Laptop accessories give a new look of a computer hiding the original feature and concept innovation. This also protects and prolong computer from getting damaged because of the compliance and purpose.
In the short-term, it might not helpful because you are re-inviting and reshaping how it's made. Changing the original concept and some considered damaging the great innovation of the maker. But as a user/owner, this is a strategic move of adding more years of life's spam of your device that you spent so much time, effort and money to get what you dreamt of.
For long term use, these;
Laptop AC Adaptor
Laptop Battery
Laptop LCD screen
Laptop LCD Inverter
Laptop LCD Hinge
Laptop Optical drive
Laptop Keyboard
Laptop Casing
Laptop Cooling Fan
And many accessories not mentioned are really great help to keep and preserve computers up to the ages, moreover centuries.
There are several accessories that protect and enhance the functions of your laptop. Some of them are quite indispensable, such as the AC adaptor that allows you to recharge the battery.
A case or a bag is recommended for the protection of the laptop. A laptop cooling pad will make the laptop run safer and will allow you to hold it in better conditions.
Adding a mouse and even a monitor or a keyboard to the laptop makes it easier to operate.
