richad-ndb
Posted on - 05/24/2012
What are the new features in MS Word 2010 and is it better than old version or not?
What are the new features in MS Word 2010?
They were able to preserve the look of the previous MS Word versions so you will find it user-friendly as ever. You may now check your documents though you are not on the computer because you can now send it to your Skydrive Account like which can be checked using Windows Live as long as you already have an account.
It still has the so-called “ribbon user interface” where you can change fonts, size, formatting, style and a lot more which is also available through the browser. For the copy and paste function, it is now updated as there’s a live preview of the document that you are going to paste.
Hai,
Here are the 5 outstanding features of word 2012
1. Integration of Screenshot feature in Word
The option of screenshot is in the ribbon at the top of your document. When you click screenshot you automatically get few screenshot samples from the background (that is at the back of the word document). You can either select from the available screenshots or click on “Screen clipping” to take the screenshot yourself.
If you select “Screen Clipping”, your word document will get minimized and a resizable window will appear over your background.
2. Remove background of Images
It’s a Photoshop like feature-not as effective though-yet its a great help. With it you can directly remove the background of any picture. It is really good for simple backgrounds while a little untidy and time consuming for the complex ones.
3. New Art Effects in WordArt
WordArt has been updated with new colorful art effects. Select the text, click “Word Art” and a list of options will appear. You can see how your text will appear when you hover the mouse over the option-which is the best part.
4. Artistic Effects
Fantastic new artistic effects have been added in Word 2010! Select the image and click on “Artistic Effects” from the ribbon. You get a bunch of options like Pencil Sketch, Chalk Sketch, Glowy Edges, Photocopy etc
5. Ligatures
Ligatures usually replace consecutive characters sharing common components. However, the application and the system still recognizes the characters in its individual components thus enabling spell checkers and search facilities.
Remember that ligatures can be supported only if they are present in the font. In Word 2010, OpenType ligatures aren’t enabled by default.
Hope these helped.
Have a nice day.
There are 10 new features which Microsoft added in MS Word 2010
1. improved search
With the new and improved Find experience, you can now view a summary of search results in a single pane, and click to access any individual result.
2. Co-authoring in real-time
With co-authoring, you can edit papers and share ideas with others at the same time. SharePoint Foundation Services or a Windows Live account is required.
3. Share documents
lets you post your documents online and then access, view, and edit them from almost any computer or your Windows phone.
Microsoft Word Web App edits documents in a Web browser when you're away from your office or home, without compromising the quality of your viewing experience.
4. Add visual effects
You can apply formatting effects such as shadow, bevel, glow, and reflection to your document text. You can spell-check text that uses visual effects, and add text effects to paragraph styles.
5. Turn your text into diagram
It offers you more options to add visual impact to your documents. You can choose from dozens of additional SmartArt Graphics to build diagrams just by typing a bulleted list
6. Image editing
New picture-editing tools in Word 2010 enable you to add special picture effects without additional photo-editing software. You can easily adjust pictures with color saturation and temperature controls.
7. Recover lost draft
Word 2010 lets you recover draft versions of recently edited files as easily as opening any file, even if you never saved the document.
8. Insert screenshots
You can now capture and insert screenshots directly from Word 2010 to incorporate visual illustrations into your work. When you use a tablet-enabled device such as a Tablet PC, you get improved tools for formatting ink as easily as you format shapes.
9. New File menu
This Office Backstage view replaces the traditional File menu to let you save, share, print, and publish your documents with just a few clicks
10. Word translation
This helps you work and communicate across different languages. It translates a word, phrase, or document more easily than before. You can set separate language settings for Screen Tips, Help content, and displays
