What are the new features in TeamViewer 9
I wanted to go for TV 9 but wanted to know first on whats new?
What are the new features in Team Viewer 9
Can i have all features listed?
Team Viewer 9 boasts of excellent features that truly empowers the team using it. Everything listed here comes with Team Viewer 9.
1. The tabs have open multiple connections. Tabs flash when there is anew activity. Plus you can view all tabs from different computers.
2. Team Viewer 9 has wake on LAN. This gives you 24/7 remote access whenever you need it.
3. Two factor authentication for added protection.
4. Compatible with Windows8.1 and Mac OS X Mavericks.
5. Customer modules can be customized and saved.
6. Clipboard allows you to copy almost everything even to a remote computer.
7. You can do file transfer without being connected.
8. You can integrate the functionalities of this application in your own environment.
9. Desk top shortcut allows for a quick connection.
10. Easy to scan notifications panel.
11. Video streaming is faster for better viewing appreciation.
