What are the new version of Mozilla’s updated features?
Mozilla has released Firefox 12 which is available for Linux, Mac and Windows. I want to know its updating features.
Firefox 12 is the recent version of Mozilla. There's a lot of changes and developments made from this version. The update process is very quiet. When you install the software for the first time, there is no need to update it. It will automatically upgrade itself. When removing the UAC dialog box while sustaining the system security, it will make the update process easy for Windows user.
Features of Firefox 12:
– Page source consists of line number now.
– Line breaks are now available on Page Source.
– Enhanced Find in Page feature.
– Various security fixes.
– Download Manager will automatically start the downloading process right after pasting the URL into it.
– And a lot more
For more details see the technical release note of Mozilla.
Mozilla Firefox 12.0 is the latest version of Firefox browser that includes comprehensive pop- up controls to keep unwanted advertising off from your desktop. It also do have simplified privacy controls. Find As You Type feature and tab browsing that will allow you to open another site in the same window allowing you to let another website run while checking on another one.
Other improved features of Mozilla Firefox 12.0:
1. It has the ability to integrate third party add-ons.
2. It uses all the history so that searching will be easier so that the links or sites that are frequently used will be in top of the list. That means that you can simply type in a keyword not the exact link.
3. Improved Firefox Synch that makes back up of the bookmarks, history, cookies and add-ons in the cloud server of Mozilla.
4. New – Windows: Firefox is now easier to update with one less prompt (User Account Control).
5. New – Page Source now has line numbers.
6. Changed – Line breaks are now supported in the title attribute.
7. Changed – Improvements to "Find in Page" to center search result.
8. Changed – URLs pasted into the download manager window are now automatically downloaded.
9. Developer – Support for the text-align-last CSS property has been added.
10. Fixed – Various security fixes
11. Fixed – Some TinyMCE-based editors failed to load.
