What are other alternative apps to infopath 2007?
Is there an alternative application or software that I can use that works exactly like infopath 2007 or works almost the same with infopath 2007?
You can find many applications like infopad that can be use as alternative to this. But if you want same like this you should use open office. It will provide other office features as well and also free of cost. You can download open office from this link.
Thank you so much.
InfoPath is a kind of unique software in it's class. Though there is no other software to surpass it, sometimes you may need to use something else when your operating system is not compatible with InfoPath 2007. There are some other stuff that may meet your demand to some extent. You may use
1. OpenOffice
2. SharePoint
3. XForms Viewer
4. Sharp UI
5. ITechnology
Links below can be useful :
