What are the other features of advance Google search?
Can you tell me more about the proper usage of that application so that I will be able to know what the security and compatibility measurement of the application are over the internet?
I hope you can share your ideas with me based on your experiences.
Thank you
Advanced Google Search has 3 Hidden Features that you could not know. It surrounds many functional features not accessible using the left-hand sidebar.
1. Look for illustrations by Region – latest and highly developed explores the options.
2. Look for videos and captures with subtitles – it proposes lots of fascinating options.
3. Look for protecting search (enabled) – to evade adult content.
Best regards,
Heather marie
With search operators you can generate many advanced search results with the regular Google search box.
These might help you,
1. Using quotes you can search for an exact word or query. Say you need complete lyrics of a song. Just type “part of the lyrics you know” and hit enter. Only the results with the exact search term will appear in the results.
2. To exclude a specific word from your results, use a dash (-) in front of that word. Eg: say you don’t want any results relating to computer appearing in your results, type -computer with the other search terms.
3. To get results from only a particular site, say techyv.com type site:www.techyv.com and your search term then only results from techyv.com will appear in your search results.
4. You can also search for websites similar to another site. In the search engine results page click the double headed arrow that appears to the right of each search result when you hover your cursor and select similar. It also gives you an option to access a cached copy of the website.
