Sara Carter
10 points
Posted on - 03/26/2013
Hello fellows, I have been enjoying the benefits of cloud computing through this so called Google docs especially its fast numerous powerful updates that almost going into similar with the well known MS Excel. I heard of this collaboration technique. What are powerful ways that Google docs collaborate in the writing process?
Hi
Good day!! Sara Carter
Thanks for your question. One of the best features of Google Docs is that you can collaborate, and I don't mean check-in, check-out collaborates like Share Point. I mean everyone can edit the same file at the same time without having to download or upload anything. You can do
Edit Your Documents Offline
Cloud Connect
Upload Anything
Make Spreadsheet Gadgets
Use Templates etc
Thanks
