What are professional quality plug-ins for 3DS max ?
There are lots of plug-in for 3ds max, I thank if you count them you need 1 years to complete and it is also hard to find the good ones because a same thing is not good to everyone but if I tell you about my experience of good plug-in then I will tell you, that the most common most important plug-in for the 3ds max is v-Ray. It is a rendering engine that makes your scene more realistic than ever. As rendering is so important and sensitive without good rendering we can’t find a good image or animation. You can buy it from this site : https://www.vray.com/ .
                                            Hi….
Yes there are lots of plug-in for the #D max application. But the problem is most of them are rubbish and useless. Some of the plug-in are lees quality. But there are lots of good plug-ins are available. To get the maximum advantages of the plug-in s you have to use them as appropriate.
Here are few famous plug-in that mostly use.
· Volume Light
· Craft Director
· Havok 3.2 & Havok 3
· Fume FX – Real fire, Flame Thrower
· Real Flow 4.2
There is other good plug-ins are the internet
Check out this link
http://www.cgdigest.com/3dsmax-plugins/
Thank you….
