What are the pros and cons of the SyncBackSE 6.1.1.22?
Some pros of the SyncBack SE 6.1.1.22 are being able to copy files that are open or locked, a file log, and filtering compression. What are other pros and cons of this product?
This “SyncBackSE” can effortlessly backup or synchronize important files to another drive, directory, or network. “SyncBackSE” is extremely configurable, but it is extremely easy to use.
“SyncBackSE” is integrating with Windows Scheduler to mechanize backup. “SyncBackSE” can easily copy locked or open files and features fast backup including stylish synchronization, versioning, influential ftp engine and AES encryption.
v New: Backup to multi-zip files on FTP files
v New (Pro): Support for LZMA compression format compatible with WinZip12
v New: Support for FTP proxy type used by McAfee Web Gateway
v New: Support for UTF8 storeroom of filenames in Zip files which compatible with WinZip 12
v New: View all the logs in a group
v New: Vista or newer pop-up balloon appears if listed profile failed to run due to wrong password
v New: Warning while, exiting and have profiles set to run on logoff
v Fixed (Pro): Now CD/DVD burning works on Windows 7
v Fixed: Log file now includes total Kbytes copied and deleted
v Fixed: impediment after resuming from sleep now applies to when, episodic profiles are run after waking computer
v Fixed: Various pop-up menus were not translated on Vista or newer
v Fixed: Keep window on top of all others option in Differences window now works as
v Updated: Automatically stops using ALLO command with FTP servers while they do not involve it
v Updated: How to network connections are made
v Updated: Dutch language translations
v Updated: Help Files
Notifications
