What are the reasons of overheating cooling fan?
To All Techyv Members:
What are the reasons of overheating of the notebook cooling fan despite the manufacturer’s of different brands continuously designing a better and greater speed? Why these notebooks are still susceptible to overheating despite cooling fan is being installed? Why is it so despite the cooling system is installed? Is there any new product that ventilation will not be clogged anymore or will no longer be impaired despite usage in normal conditions? I am so much afraid that this will lead into a fire in the house and will create more problem. This will be another problem as a consequence of using the notebook.
Best Answer by Bradley Charpentier
Answered By 0 points N/A #184436
Hi alice
Well to find best answers for your questions about « overheating » you must first be aware of reasons that may cause this,mostly the main causes for overheating are related to video games ,graphic design programs..etc,so to fix your notebook you should first locate/find the heat source try to clean dust from your vents/fans also you should verify the batteries you use i recommend to use it from time to another because most people keep their laptops on charge all time,if cleaning fans/vents verifying batteries didn’t fix your problems you have to verify your RAM and processor and try to clean it of dust also same as you did for fans/vents,i recommend that you avoid using some applications and programs that might effect your CPU and cause overheating.finally you can use cooling pad made specially for laptops you can connect it to your pc via USB cable.
Answered By 0 points N/A #184438
Hi Alice, Glad to meet you, The reasons why a laptop or notebook cooling fan is overheated is because, of a continuous long usage of it. I have experience of it because I myself have a laptop cooler last 2011. Unfortunately the cooler is damaged. Now even my laptop as well sad to say. Another reason is the dust that clogs the sink of a cooling fan, it should be clean every 3 days of usage.
