What are the softwares and the hardwares needed to record TV channels
What are the software and hardwares needed to record TV channels. I have a Laptop and wanted to have some of my favorite channels recorded as needed?
What will I need to achieve this?
Best Answer by Waters Magner
Answered By 5 points N/A #86635
SnapStream TV Recorder is what you definitely need. You can record TV broadcasts just like a home DVR. You can record an episode or all episodes in a channel.
It has easy-to-navigate electronic program guide, priority recording so you can choose the order of episodes to download, and manage 24/7 block recordings.
SnapStream is a hardware with a built-in software to browse and record TV channels. Please click this link to know the price quote.
Answered By 5 points N/A #199061
I will recommend TV tuner card rather than HDMI cable. You can also go for software such as Blaze video TV recorder. Both of these are going to solve your computer. The easiest method right now is the TV tuner card. However, you can use the Blaze video TV recorder as well. It will first save the program in TV format and then afterwards you can convert it into any format that you require to share with friends.
Waters Magner
