Hi all,
I'm looking for a utility software that can allow me access the files on my computer through a Bluetooth wireless connection. It could be a Window based Bluetooth Script Software. Any ideas?
I appreciate your details.
What are some Bluetooth Scripts Windows Software??
You can access the files on your computer through a bluetooth wireless connection without using any software.
Just follow these simple steps:
1) Open bluetooth places.
2) Choose properties from my file transfer.
3) Choose whether you want to start the transfer manually or automatically.
4) Modify permissions to remote users.
5) Use security options If you want to add a security code.
This will be possible if you have another device which is Bluetooth capable such as a mobile phone. Since Android is one of the most in demand OS as of today, you can try to download Bluetooth Remote PC. This will let you access your computer from distance. Download it from the link.
But you need to remember that Bluetooth Wireless Connection is usually slow. It can range for up to 10 meters only. The best way to access your computer remotely is to use WiFi. And use Remote Desktop applications such as TeamViewer.
