s.lopez
Posted on - 07/14/2016
Hi, I am using a Windows 7 operating system in my dell laptop. I do not care for the basic calendar which came pre-installed in my laptop. I need information about some good calendar programs for Windows 7.
What Are Some Good Calendar Programs For Windows 7
Let me tell you about some of the best calendar programs for Windows 7:
1. Rainlendar
Even though it may not sound very user friendly, hear me out. It understands that calendars are not just a look up for dates. As you’re browsing dates on rainlendar, you can set reminders for tasks, create events and even set up alarms. Also, a lot of customizations are available.
2 WinCalendar
WinCalendar the best designed desktop calendar, which also has the ability of designing amazing looking printable calendars. All the features and the size of the calendar can be customized to suit your needs, and the support system of wincalendar is optimized for the best service.
