What are some of the most affordable portable scanners?
The current trend is the more portable a device is the better.
I have been scouting the web and some computer shops for portable scanners.
Can anyone recommend affordable portable scanners?
These are some excellent portable scanners that worth buying. You can coose one of these.
The Canon CanoScan LiDE110 Scanner, The Fujitsu ScanSnap S1300, The VuPoint Magic Wand Scanner, NeatReceipts Mobile Scanner, The Epson Perfection V330, Brother DSMobile Scanner, The CanoScan LiDE210 Scanner, The Canon imageFORMULA P-150, VuPoint Magic Wand Portable Scanner, Epson Perfection V30, The Genius Colorpage-SF600, VuPoint Solutions Magic Wand.
Well it depends on what you want .I mean you can buy second hand or new. It all depends with your choice. I made a look on amazon and saw that it offers the cheapest at $44.95 and for used ones at $36.5 have Allok at this https://www.amazon.com/VuPoint-Solutions-Portable-Scanner-PDS-ST410-VP/dp/B002R0BFAAÂ Â
At Shopbot the lowest is sold at $17.99 and find it here https://www.shopbot.com.au/
