What are some recommended Apps for iPads?
Hello everyone,
I am new to the Apple Family and my job is giving me an ipad.
I was wondering what are some apps that are fun and useful that you all would recommend.
Hello everyone,
It depends on what you would like to do while using your iPad. I suggest checking out these great apps for getting started.
Notes Plus is our go-to app for note-taking and worth every penny. It will even turn handwriting into type-written text!
Snapseed is the best photo editor available for iOS and it's FREE for the next few days so GRAB it now!
I hope this helps! Don't hesitate to email if you have any other questions!
You may also check this for more updated iPad apps.
Hi Newipad,
With regard to your concern, I highly recommend that kindly check Apps Store and you'll will see there what are the latest Apps for your iPad. Also, there is a category for you to select whichever you like. There are two type of apps, one is the "Free Apps" which you can download a specific apps for free. And the other one is "Paid Apps", which is you need to enter your credit card details in order for you to download that specific apps. Here's the catch, once you've downloaded a paid apps, it will ask you for a one time payment. To go to Apps Store using your iPad, just tap on Apps Store and you'll be redirected to Apps Store Homepage. And also, you can download apps in Itunes Store if you have iTunes on your computer. Hope this might help you to your query. God Bless
