What are some ways to install chinese USB format tool?
Hi Expert,
I tried to install Chinese USB format tool in my pc but the program doesn't work. I want to know some ways to install Chinese USB format tool to insure that it will work.
Thank you.
Answered By 0 points N/A #158028
Hi jafet,
If you're installing the format tool by using an USB device, you have to confirm the following things:
At first you have to test your device to be sure about write protection. Because write protection option will keep you away from installing or to copy file from the device. You have to get rid of Write-protection if write protection exists.
Whenever you are able to access the set up wizard, you need to place the setup.exe data file and double click on the setup file. Now, the installation process will be started soon. You can follow the directions of your tool.
Regards
Jenny
Answered By 590495 points N/A #308384
Since you did not mention the name of the Chinese program you installed, just check if the program is compatible with your computer. Before installing any application or tool on your machine, make sure your computer meets the requirements. Visit the website where you downloaded the tool and check its system requirements. One reason why a program doesn’t work is incompatibility.
There are programs that will install though the platform or operating system is not supported but the majority of software checks the target platform before initiating the installation. You also need to check if the program requires additional components like Microsoft .NET Framework, Microsoft Visual C++ Redistributable, and others. If the program requires some prerequisite components, you need to install them first before installing the actual program.
