Which programming language is used to program? Can there use any other programming language? What is DSP and how does it work? Where are DSP and Microchip Technology similar? What are DSC devices available; describe its clock speed, PWM channels, resolution, duty cycle. How DSC is important in Diagnostics and Therapy area? What is a 16 bit digital signal controller? What type is available in 16 bit Microcontrollers? Can 16 bit digital signal controller be used in sensor processing applications? Thank you
What are specification in The Digital signal controller
The digital signal controller is a hybrid micro controller and digital signal processor are combined. The microcontrollers have fast interrupt response and offers oriented puns and watchdog timers.
They are usually programmed by c programming, they programmed using device accumulators. The most digital signal processor is multiplying accumulate and large accumulators.
The vendors are adopted in terms of DSC. The term introduced by microchip technology in 2002.The 6000 series and digital signal processors are subsequently adopted by most, all DSC vendors.
For example DSC's microcontroller.
“DSP” stands for “Digital Signal Processing”. It refers to different methods for enhancing the accuracy and dependability of digital communications. It is the process of analyzing and modifying a signal to enhance its performance. This involves applying different mathematical and computational algorithms to digital and analog signals to create a signal that is of higher quality than the original.
It is the use of digital processing like by using a computer or more specialized digital signal processors to perform a wide variety of signal processing operations. The use of digital computation to signal processing allows for many advantages over analog processing like error detection and correction in transmission including data compression.
The use of DSP is mainly to detect errors and to filter and compress analog signals in transit or during transmission. Normally, DSP first converts an analog signal into digital then applies signal processing techniques and algorithms.
