Max Smith
30 points
Posted on - 06/05/2012
Gamers behold. Asus showed love to the gamers all over with the release of its Asus ROG Tytan CG8890 PC.
I was awed with its rigid design but what about the specs?
 What makes this stand out with the current PCs gamers use?
 How many drivers does it have?Â
What Are The Specs Of Asus ROG Tytan CG8890?
Asus ROG Tytan CG8890 is great with design and hardware features.
The specs of Asus ROG Tytan CG8890 are:
-Intel X79 Chipset
-Intel Core i7 3960X 3.3GHz
-16GB of DDR3 RAM 2133MHz
-2TB 7200RPM drive for storage
-Two 128GB SSD
-Asus Xonar DX
-And a Bluray writer
You will be amaze on the design of this PC specially when you click on top of the casing and once it open on both side, you will see some parts of the system.
It also has overclocking modes so that you don't need to reboot the PC. It overclocked up to 4.2GHz.
Finally folks, the greatest of all times Pure Gamers Machine by Asus has arrived. The big giant called "ASUS ROG Tytan CG8890" with turbo gear, no rebooting required. The serious Gaming Machine specifications yet known are:-
Intel Core i7-3960X consisting of 6-core
Containing Intel X79 chipset
6GB DDR3-2133MHz RAM
Graphics processing unit (GPU)Â Â Â NVIDIA GeForce GTX 690 Â
Storage  2TB 7200RPM + two 128GB SSD in RAID 0
Almost 10 way venting and Integrated liquid cooling system
ASUS xonar DX sound
Optical Blu-ray writer
The main housing of pc is real stunning thing
Single touch over clocking modes
The speed button: 3.8GHz, followed by 4.0GHz and finishing with 4.2GHz
The beautiful and wonderful gaming machine.
