Photos and specs of the new 13-inch MacBook is all over the Internet. This has been leaked by one of the Apple's employees and published by a Chinese website.
Apple has not released this yet, and I'm wondering if they'll be changing some of the features now that the specs have been spilled. How true that this new book from Mac has two USB 3.0 and a Bluetooth 4.0 support?Â
What Are The Specs of The New MacBook Pro?
The most common revision for a new machine is the style. And the report is pointing out that it will be considerably thinner than the common MacBook Pro because of the optical drive that can be remove. It is generally a type of the thinner version of the MacBook Pro as an alternative on fostering the narrow style of the MacBook Air as reported earlier.
The forthcoming MacBook Pro casing consists of ports that you can use in connecting the following:
    – MagSafe Power Connector
    – USB Ports
    – Audio In/Out on the left surface
    – Battery level indicator in addition to connected surface
    – The proper surface is said to accumulate a connected Thunderbolt ports.
    – SD Card slot
    – Kensington lock slot
    – Another USB port
This machine doesn't have an Ethernet port, with users seemingly outrageous to assume about the USB-to-Ethernet dongle announced on the first MacBook Air if they will use a wired connection. With its height, the Ethernet port is one between the first options restricting to how slender the MacBook Pro would be. And it looks like Apple could slightly take out the port completely so as to think about the emaciated style it aims. The new MacBook Pro can also do without the FireWire connectivity, but the report looks doubtful on that time.
Next to the prior rumors, it is claimed to combine a Retina show, an improvement that has been reported for many times and that evidence had been telling in OS X Lion and Mountain Lion Builds. According to the report, OS X can slightly give a group of resolution quality choices for the new machine either it is huge, small or optimal to allow the users impose of this new HiDPI support to discern their wanted combination of sharpness and perseverance.
The report signifies that the USB ports on MacBook Pro can support USB 3.0. This is the characteristic that some is asking whether or not Apple would affirm given the move to Thunderbolt connectivity. But on September, it certainly was stated was giving support to USB 3.0 besides Thunderbolt, which appears to be the course the corporate has seized as Thunderbolt elements are fairly slow to stand out in various cases. As current report from Digitimes also acknowledged that Genesys Logic achieved a contract to support USB 3.0 chips on the expected MacBook Air amendment, and apparently, it shows that such compatibility will go back to the MacBook Pro.
A launch period of time for the new MacBook Pro was still obscure, with the corporate expected to be able to announce latest machines any time on present time as Intel's Ivy Bridge production lifts up. On Apple's Worldwide Developer Conference, it is possible that the corporate might utilize the event for a meaningful product initiation, however Apple commonly restrict its hardware declaration at the event and to focus on iOS and OS X conference. Digitimes said that the Apple MacBook suppliers will start accumulating their shipments on June with the production maximizing in July, indicating that Apple could actually be aiming a meaningful development for June.
Specification of the new 13-inch MacBook
Speculations have been going up and down the internet regarding the upcoming launch of the new 13-inch MacBook Pro. This became apparent when claims that images of the new 13-inch MacBook Pro were linked into the net. The New 13-inch MacBook Pro comes with a wide range of specifications some of which are a major upgrade from the once famous 13 -inch model. It boost of a 2.5 GHz dual-core processing ability of Intel core i5 processor with a 3MB shared L3 cache. This can also be provided with a 2.8GHz dual-core Intel core i7 processor with4MB shared L3 cache. This is a major shift from the earlier 2.4 GHz 13 inch model.
On the flip side thou the new 13-inch MacBook Pro share the same RAM and Hard drive size as its earlier edition. It also shares the same 8X SuperDrive optical drive as its predecessor. However, as has been the norm, a Thunderbolt port will be incorporated into the computer having two 3.0 USB ports as opposed to the normal 2.0 USB port. With some mentioning that it will also enable a Bluetooth 4.0 support. Talk about innovation.
